April 28, 2022, 05:51 |
Remote viewing STAR-CCM+ batch simulation
Leonardo
Rep Power: 5 |
Hello!
We have a lsf cluster at my job which we use to run simulations. We are interested in setting up remote access to the simulations, in order to check them while they are running and, occasionally, to have a GUI access to mesh while using more cores than our personal workstations have. For security reasons, the all the comunications from and to the cluster are cut, and the way we access it to submit jobs is by ssh-ing into a local machine (which is simply a docker interface) and submitting jobs with bsub from there. The general procedure for remote viewing seems to require setting up a direct ssh tunnel, but in my (admittedly scarce) understanding of network communications, this doesn't seem to be possible. Does anyone know how this problem could be solved? Thanks in advance, Leonardo |
April 28, 2022, 15:23 |
Lucky
Rep Power: 66 |
Let's go through some basics. If you have a workstation and the colleague sitting right next to you has a workstation, do you know how to use the Star client on your workstation to view a simulation running on their workstation?
April 28, 2022, 15:45 |
#3 | |
Leonardo
Rep Power: 5 |
From my understanding, the short of it is:
The act of setting up the passwordless ssh looks a bit complex, but every guide has a very good step-by-step explanation of what to do, so I should be able to set it up. |
cluster, cluster computing, remote access |
Full view of an axisymmetric simulation in Star CCM+ | killian153 | STAR-CCM+ | 6 | October 11, 2023 18:04 |
Import Table Data For a New Simulation in STAR CCM+ | Raamses | STAR-CCM+ | 3 | March 18, 2021 21:15 |
Aeroacoustic/Hydroacoustic Simulation in STAR CCM | BlackEagle | STAR-CCM+ | 0 | March 30, 2018 12:00 |
Help with Star CCM versions | patilsachin | STAR-CCM+ | 2 | March 8, 2018 04:20 |
animation of transient simulation using batch file | Markus | FLUENT | 1 | October 17, 2007 11:30 |
