Raj Dasari
Rep Power: 4 ![]() |
Hello everyone. I'm trying to simulate the water flowdown from a surface. I doing a multiphase simulation .Initial conditions are like the suface is covered with 1mm thickness of water and rest of the domine is filled with air. The inlet conditions are 0.05m/s and outlet is pressure outlet only the air comes out not the water. While running the simulation the there was a reversed flow at the outlet. How can i avoid this reversed flow. could you give me some suggestion to avoid this case.
initial conditions, reversed flow., star ccm+ |
reversed flow at outlet for bubble column | melj | Fluent Multiphase | 4 | August 30, 2021 00:37 |
reversed flow in xxxx faces on pressure outlet | franzdrs | FLUENT | 8 | January 4, 2020 20:12 |
Reversed flow in XXX faces on pressure outlet | parradux | FLUENT | 6 | May 2, 2015 04:26 |
reversed flow when using Exhaust Fan as outlet | Dziyad | FLUENT | 0 | February 20, 2014 20:13 |
Reversed Flow in Outlet | Steve | FLUENT | 18 | March 30, 2013 07:50 |
