April 8, 2022, 08:43 |
6DOF F = m a ?
Will Crawford-Jones
Rep Power: 5 |
I'm testing a DFBI contact model in Star-CCM+ and have noticed that if I apply a constant force of 1N to a 1kg mass via a field function and observe the acceleration using a report, I found the acceleration during the first time step is = 0.5 (you'd expect it to be =1). From the 2nd timestep onwards it becomes = to 1, as would be expected. Firstly, what is causing this? I noticed that in the manual it says "For time integration, the 6-DOF solver employs a trapezoidal scheme of second order accuracy", is this the reason? Although, I noticed under Theory > 6-DOF Rigid Body Motion > Equations of Free Motion it gives f = m .dv/dt. Secondly, is it possible to 'switch' this off, such that a 6DOF body simply moves with f / m = a ? Thanks |
6dof, 6dof solver, user defined |
why fluent 6dof rotational mass cannot be changed?? | EngGhost | FLUENT | 7 | February 1, 2023 00:40 |
Modelling Contact and Frictional Force in 6DOF | wcj1n18 | Fluent UDF and Scheme Programming | 2 | March 12, 2021 05:17 |
Buoyancy and the 6DOF solver (FLUENT) | i2a | FLUENT | 16 | March 20, 2020 12:20 |
Using 6dof for 3D turbine rotation | mg.mithun | Fluent UDF and Scheme Programming | 8 | July 24, 2018 01:53 |
How to get the rotate speed in 6DOF simulation? | jealor | Fluent UDF and Scheme Programming | 0 | April 20, 2018 23:08 |
