April 4, 2022, 02:33 |
How Can I control the first volume mesh??
Seung Won Lee
Hello, everyone..
I need your tips.. The first volume mesh is so big.. I know I have to make the growth rate gradually.. so.. How can I control the volume mesh size after prism layer?? and then, How can I make my mesh grow gradually? without controlling the prism layer total thickness.. |
April 4, 2022, 06:10 |
Lucky
Rep Power: 66 |
Actually, the first volume cell is roughly the same as the surface size. This much has nothing to do with a gradual change in volume meshing characteristics. You should be tweaking the target surface size and prism layer thickness to get a more gradual transition there. Lowering the target surface size of course will greatly increase the cell count if you don't do other things.
The other two properties you need to look for is the maximum tet size and volume growth ratio. The maximum tet size controls the size of the core mesh. The default is 100% of the base size. You can change this to have the core mesh cells bigger/smaller than the typical surface size. The volume growth ratio is the parameter you're asking about. The default value is already quite low. But you can lower it down to 1.1 if you want a super slow growth. But the volume growth controls the core mesh changes from one volume cell to the next. The abrupt change between prism layer and volume will still be present until you do what is noted before. |
April 4, 2022, 09:28 |
Seung Won Lee
It means, when I want to make the mesh gradually, on the point which changes from prism mesh to volume mesh(first volume mesh), I have to change the surface target size and prism total thickness.
It' very helpful for me Thank you for your answering.. I had just controlled the maximum tet size and volume growth rate.. |
mesh control, star ccm+ |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 08:38 |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
CFX FSI Fatal Error | unbanana | CFX | 0 | October 3, 2015 06:57 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
