CFL Number
Old   March 10, 2022, 14:45
Default CFL Number
Ash
ashf9 is on a distinguished road
Does anyone know what the CFL number does and is it applicable to steady flow simulations. When I run my simulations I sometimes get the error saying
AMG solve rejected. CFL 216.14 -> 108.07. Would someone be able to explain to me why this is the case and what a reasonable CFL number would be for an aerofoil under stall?
Many Thanks,
ashf9 is offline   Reply With Quote
Old   March 10, 2022, 15:31
Matt
fluid23 is on a distinguished road
The steady solver uses a pseudo-time marching approach so there is still a CFL number. From the output you shared, it looks like you have the default 'automatic control' option enabled and what's happening is the solver is advancing, trying to manage your CFL number to speed up convergence. It didn't resolve the iteration at the CFL it had chosen, so it reduced it's guess and tried again.
The default limits for auto control are a little ridiculous in my opinion. I usually impose a new (lower) limit when I start seeing AML rejection repeatedly.
fluid23 is offline   Reply With Quote
Old   March 11, 2022, 05:14
Ash
Ah I see, thank you I've set the limit to 500, but the problem is it converges nicely for a 2D case but when I impose it on a 3D simulation with 2 slip walls, it doesn't seem to be converging, would you say I need to go lower?
Old   March 11, 2022, 10:25
Matt
The value of the CFL number shouldn't make a difference in the final result as long as it isn't so high that the solver is unstable or so low that the solver is too stiff. Poor convergence can be due to a number of things, most commonly poorly posed boundary conditions and/or poor quality mesh. I would start there in trying to track down convergence issues.
May I ask how you are judging convergence? Many people place too much emphasis on residual convergence. The 3 orders of magnitude rule that you often see quoted is a good place to start, but if you have a really good initialization, you may not get 3 orders of magnitude. I have run into this using the grid sequencing expert initialization option.
In such cases, it is helpful to consider the magnitude of the residuals, not the normalized residuals, where they are occurring in the domain, etc. You can setup your own residual monitors by turning on temporary storage and creating some plots. I have gone as far as to create separate residual plots for separate regions to help me understand what was happening with the domain.
All I am saying is, don't get hung up on residual convergence. Convergence of figures of merit (drag coefficient for example) is much, much more important. I have seen flow fields where the residual plots are converged but the things I care about in the flow are still asymptotically approaching some value.
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops avinashjagdale OpenFOAM Meshing & Mesh Conversion 53 March 8, 2019 10:42
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
foam-extend_3.1 decompose and pyfoam warning shipman OpenFOAM 3 July 24, 2014 09:14
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
