Residuals Not Converging
Old   March 5, 2022, 09:21
Default Residuals Not Converging
Ash
ashf9 is on a distinguished road
I am doing a 3D RANS simulation on an airfoil under stall conditions. I've done a 2D simulation with the same boundary conditions and it converged to 1e-5. For the 3D simulation, I extruded the boundary by the span and set the walls to a periodic wall boundary condition to replicate endplates. However, my residuals are not converging past 1e-2, and I'm not too sure why? The turbulence model used is k-w and the Y+ along the airfoil is <1.
I understand unsteady RANS is usually required, but I'm trying to figure out how to get the residuals to converge, as this has been done before and worked with the 2D simulations.
Thanks
ashf9 is offline   Reply With Quote
Old   March 5, 2022, 11:13
Matt
fluid23 is on a distinguished road
My first question; is this a steady or unsteady analysis? If you are trying to model an airfoil under stall using a steady solver, you are wasting your time. Stall is the result of flow separation which typically results in a dynamic flow field.
fluid23 is offline   Reply With Quote
Old   March 5, 2022, 17:29
Ash
It is steady at the moment. So I presume for this simulation I would have to change the physics method to implicit unsteady.
I have seen some papers using steady RANS simulations before to capture stall cells, and I am trying to replicate this.
Old   March 6, 2022, 09:31
Matt
That would be my recommendation, yes. However, if you are trying to duplicate data from a paper you should follow whatever methodology they have employed in said paper.
Old   March 9, 2022, 12:47
Ash
So I am trying to follow that methodology but I am still getting relatively high residuals and difficulty in converging.
Old   June 4, 2024, 08:31
Uttam
openfoam_aero is on a distinguished road
Hi. So I am also doing the same thing. I have found that the spanwise spacing makes a huge difference. I am trying to run a case at 14 degree AoA at 400,000 Reynolds number with an AR (span/chord) or 2.5. I started with a span of 0.5 and increased it to 1 and 1.5 and then 2. I managed to get the number of stall cells = AR. The spanwise spacing is kind of trial and error so I am still working on that. I could share more details if you are interested. Or if you solved it, perhaps you could help me.
Btw, my residuals converged down to 1e-05
Best Regards
Uttam
“When everything seem to be going against you, remember that the airplane takes off against the wind, not with it.” – Henry Ford.
openfoam_aero is offline   Reply With Quote
convergance, residuals
Residuals not converging, but staying stable and fluctuating ashf9 Main CFD Forum 4 March 3, 2021 16:13
Pimplefoam - residuals not converging cyln OpenFOAM Running, Solving & CFD 16 November 7, 2017 13:46
strange residuals - converging -then diverging- then oscillating - then getting weird juste FLUENT 3 December 3, 2016 18:26
Residuals of continuity not converging hjxy2012 FLUENT 3 August 27, 2016 00:30
Solution not converging, but oscillating residuals around a constant value Irene FLUENT 2 February 7, 2012 12:55
