Problem with flows not being able to enter a tube
Old   February 21, 2022, 15:11
Default Problem with flows not being able to enter a tube
Hollis Williams
HWilliams79 is on a distinguished road
I have a box with an outlet at one end and four inlets into which I feed four different gases (two of the gases enter through large pipes with large mass flow rates and two of them enter through small pipes with small mass flow rates).
The problem I have is that the two gases going through the small pipe start to enter the box but then get suppressed by the gases with the larger mass flow rates which flood the box and are unable to proceed further (as shown in the attached image).
Is there some kind of backflow going on?
HWilliams79 is offline   Reply With Quote
Old   February 22, 2022, 01:31
Lucky
What is even being plotted? What even are the boundary conditions?
Old   February 25, 2022, 07:02
cwl
Chaotic Water
cwl is on a distinguished road
How do you detect it / what makes you think so?
cwl is offline   Reply With Quote
Initialization with two different initial states-Shock tube problem.!!! Vino SU2 9 August 3, 2022 13:20
[ANSYS Meshing] Interface wall problem between outer tube face and external flow domain Onurozcan ANSYS Meshing & Geometry 0 February 21, 2016 08:47
[ANSYS Meshing] Problem in Meshing a tube in tube Helical HX Maradona ANSYS Meshing & Geometry 0 August 4, 2014 08:50
Shock Tube problem mouna lamnaouer FLUENT 1 September 22, 2011 13:47
Need help in setting up a shock tube problem kalee FLUENT 0 November 2, 2007 15:11
