Daniel Riveros
Rep Power: 10 ![]() |
Hello, I am running a simulation about ship resistance including the DFBI model for rotation and translation. I have activated the Z translation (Sinkage) and Y rotation (Trim) in the free motion model. When running, the body release ramp starts at 1.0 s and it ends at 5.0 s. My simulations start correctly but after the time 2.0 s, the whole domain starts to fall. I attach the GIF of the Isometric scalar scene to show what I mean. Based on the Position Z [m] color scale, you can see how absurd values this variable reaches. You can also see how the outline of the domain disappears, therefore, the domain is also falling.
I make clear that the body in the DFBI tree is only composed of the Deck and Hull surfaces. Has any of you experienced this situation? Have you found the source of the error or any hint to solve this issue? ![]() Thank you. ![]() |
Kevin Chia
Rep Power: 0 ![]() |
I also need help with this. However, my domain stayed but my ship sanked.
Rep Power: 12 ![]() |
DFBI is a region based model (edit: I am not very sure of this sentence). If you have only one region, the motion will effect the regions boundary. So, the falling of the entire region is funny but correct. Maybe you over-weighted the DFBI object? High denisty can cause sinkage. |
#4 | |
Lefteris
Rep Power: 15 ![]() |
I agree about checking the weight of the vessel but there seems to be more to it than that in DRiver's setup.
Lefteris |
#5 | |
Thank you for addition. If there is an overset region it travels inside the background mesh. If there is only one region the region still travels. If you use only 2dof, of course the ship will not move towards the x direction. You can check this video and you can see that whole region is rotationg and translating. https://www.youtube.com/watch?v=jFtZKNMVrc0 I may wrong, I will check the documentation. |
#6 | |
Lefteris
In my setup I don't use overset, it's not needed. I use morphing mesh. And I don't quite need the movement in the x direction, I only allow heave and trim. That's perfectly doable with 2 dof, 1 region and morphing mesh. I'm still curious why the domain moves in the original post. It would be good if we had more details about the setup.
Lefteris |
dfbi, falling, free motions, ship resistance, sinkage |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
Domain size influence in unbounded domains model | Reoyo | Main CFD Forum | 10 | May 4, 2018 08:30 |
Closed Domain Buoyancy Flow Problem | Madhatter92 | CFX | 6 | June 20, 2016 21:05 |
Setting rotating frame of referece. | RPFigueiredo | CFX | 3 | October 28, 2014 04:59 |
