How do I disable prism layers on a specific boundaries? |
January 23, 2022, 08:43 |
James
Rep Power: 5 |
I have a domain with a wheel at its centre on the bottom plane and I am modelling wheel rotation in an automotive application.
I am using an automated mesh and obviously only require prism layers on the bottom boundary (the road) but I have prism layers on every boundary (except velocity inlet and pressure outlet). Is there any way to remove prism layers from the left, right and top walls specifically when using an automated mesh? |
January 23, 2022, 10:28 |
Lucky
Rep Power: 66 |
Create a surface control with the setting to disable prism layers and assign that control to those surfaces.
January 23, 2022, 11:00 |
James
Rep Power: 5 |
I have managed to remove the prism layers using surface controls but there is still a high cell concentration close to the boundaries.
January 23, 2022, 13:01 |
James
Rep Power: 5 |
I have just adjusted the surface size to a large value which has done the trick. Thanks for you're help
automated mesh, boundaries, prism layer, prism layer meshing |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
How to determine number of prism layers and total height | ekraft | FLUENT | 1 | July 13, 2016 03:33 |
Prism layers and grid dependence study | jcamilleri | STAR-CCM+ | 4 | July 7, 2014 14:47 |
Getting prism to inflate into mixed tet-hex meshes | Joe | CFX | 16 | October 10, 2011 08:06 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
