Drawing Curvature in a Simple Geometry
Old   January 22, 2022, 18:59
Default Drawing Curvature in a Simple Geometry
Hollis Williams
HWilliams79 is on a distinguished road
I am attempting to draw a simple geometry in STAR CCM+ which I have shown in the attached file (since the geometry is relatively simple I am trying to do it directly in STAR CCM+ without using CAD software).
On the left-hand side I am able to draw the circle at the end of the box but I need this curved part that you see (pointing to it with a red arrow).
This curvature is just due to the extrusion process which is used to make the device. The inside of the device is a hollow box but I have drawn the way that the wall curves down towards the floor of the box.
HWilliams79 is offline   Reply With Quote
Old   January 25, 2022, 00:12
cwl
Chaotic Water
cwl is on a distinguished road
You could extrude the sketch in the "right" direction (as direction from one green surface towards another).
Or you also could make a box and fillet the corners.
cwl is offline   Reply With Quote
geometry issues
[ANSYS Meshing] Non-sweepable Simple Geometry yanki ANSYS Meshing & Geometry 5 April 3, 2018 11:01
[snappyHexMesh] simple geometry with big problems Tobi OpenFOAM Meshing & Mesh Conversion 6 October 26, 2012 19:34
How to simulate on geometry with curvature seboxx OpenFOAM 1 January 18, 2012 06:43
[ICEM] Creating Simple Geometry Mudblood ANSYS Meshing & Geometry 1 June 8, 2010 21:26
Cooling simple 3D geometry problem Luk FLUENT 4 May 12, 2006 10:47
