Aeroacoustics Simulation in Star CCM+ using FW-H Model
Old   January 21, 2022, 12:54
Default Aeroacoustics Simulation in Star CCM+ using FW-H Model
Raven
ram2013aero is on a distinguished road
I am trying to simulate the aeroacoustics noise generation due to a flow over an open cavity using Broadband Noise Model and also noise propagation in the far field using FW-H Model.
The Star CCM+ user guide explains the aeroacoustics simulation for flow over a cylinder. In the process the pressure probes near the wall surface are used in order to calculate sound pressure levels during the analysis.
The FW-H module comprises both receivers and surfaces and I want to calculate the sound pressure at the receiver location. Also the receiver location is out of the computational domain.
To calculate the sound pressure level, I can just select the pressure points which are added in the derived part. I can not make FFT for pressure oscillation at receivers location. There is no option for that. How can I make this?
I need the methodology for calculating the sound pressure at the receiver location and making a FFT to plot SPL vs Frequency in Star CCM+.
ram2013aero is offline   Reply With Quote
aeroacoustics, cavity flow, open cavity, star ccm+
Table bounds warnings at: END OF TIME STEP CFXer CFX 4 July 17, 2020 00:44
abaqus star ccm co simulation Mustafalboro STAR-CCM+ 0 July 25, 2017 17:13
Using radiation model for simulation of flat plate solar collector marjanbn FLUENT 1 February 24, 2017 18:22
Using radiation model for simulation of flat plate solar collector marjanbn FLUENT 2 March 15, 2015 11:27
URGENT-Simple Oil pump simulation using STAR CCM+ Race7373 CFD Freelancers 5 October 26, 2013 03:59
