Water sticking to surface of hull in waves when y+=1 |
December 21, 2021, 06:09 |
Çağrı
Rep Power: 11 |
Hey all,
I have a problem with boat-in-waves type of simulation. As can be seen from the video, when y+ values are close to 1, some of the water from waves sticks to the bow of the hull and stays like that. Doesn't happen with the same conditions when wall functions are used with coarser first cell height (y+>30). Anyone has had a problem like this before? (y+=1) (y+>30) (Higher resolution) https://gfycat.com/rawzanyaffenpinscher https://gfycat.com/jitteryamusedcoelacanth Last edited by cagriaydin; December 21, 2021 at 10:03. Reason: more obvious gifs |
December 21, 2021, 07:01 |
Peresvet
Rep Power: 5 |
https://www.researchgate.net/post/Y_setting_in_Star_CCM
It depends on your choice of turbulence closure. If you choose the k-epsilon turbulence model with a wall function near the wall, y + should be between 30 and 150. However, if you are using Spallart-Allmaras turbulence closure or k-omega, you should use y + close to 1. Since these two models should work for a viscous sub-layer. |
December 21, 2021, 09:52 |
#3 | |
Çağrı
Rep Power: 11 |
December 21, 2021, 20:44 |
Peresvet
Rep Power: 5 |
Let me ask you. Why did you choose this way of solving the problem? Why are you not satisfied with the standard solution that allows you to solve problems in automatic mode? Are you not satisfied with an error of less than 0.1% ?! I am working on version 16.06.
Thank you for your reply. |
Error in gmshToFoam on ESI v2106 | siefer92 | OpenFOAM Programming & Development | 4 | July 17, 2021 05:11 |
Simulation of varying contact angles for a large droplet of water on a surface | cp703 | CFX | 5 | July 20, 2013 06:08 |
swimming pool water surface motion due to wind | J.Kim | FLUENT | 4 | May 5, 2006 10:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
uptodate water distribution network | fredius,magige,tanzanian,(e.a) | Main CFD Forum | 0 | January 27, 2002 07:10 |
