November 22, 2021, 13:19 |
Loading User Code in Simulation
Will Crawford-Jones
Rep Power: 5 |
I'm trying to load user code in a simulation which is a copy of a simple example in the user manual. In the manual, i'm following a section "Creating a User Library on Windows". In my directory I have uclib.h , UserFunctions.lib and Contact_Script_Code.c . All of which were either found in a directory that comes with installation (UserFunctions.lib) or I copied exactly from Star-CCM+ manual. I then opened "x86 x64 Cross Tools Command Prompt for VS 2019", went to the correct directory and typed cl /MD /D_WINDOWS /DDOUBLE_PRECISION -c Contact_Script_Code.c There are no errors at this point. Contact_Script_Code.obj appears in my directory. I then type link -dll /out:libuser.dll Contact_Script_Code.obj UserFunctions.lib There are no errors. I then have libuser.dll , libuser.exp and libuser.lib in my directory. I then proceed to Star-CCM+ , go to tools, user code, right click, new user library. It gives me the option to upload "libuser.dll" and it simply says "WARNING - Could not load user library registration function" Any ideas what i'm doing wrong here? Please let me know if you have any questions about my approach. Thanks Will |
November 24, 2021, 08:11 |
Will Crawford-Jones
Rep Power: 5 |
Guys,
Has no one got any ideas here? Will |
November 26, 2022, 21:32 |
Have you solved the problem? I have encountered the same situation today.
#3 | |
LiuKexin
Have you solved the problem? I have encountered the same situation today. |
user code |
Error code: 126 loading compiled udf library into fluent | Perigee | Fluent UDF and Scheme Programming | 3 | August 25, 2022 15:15 |
About parallel couple cfx with other code using user fortran | Jinzhihui | CFX | 2 | June 6, 2021 00:39 |
Looking for experts in Starccm+ to help me write user code files | highend | CFD Freelancers | 4 | March 11, 2019 04:49 |
User Code for HPC | nalamyogesh | STAR-CCM+ | 3 | March 3, 2019 18:54 |
How to build a source code for simulation of combustion | syoukera | Main CFD Forum | 0 | July 31, 2018 08:13 |
