2d Axisymmetric Pressure-Swirl Atomizer Floating Point Error
Old   October 18, 2021, 17:39
Default 2d Axisymmetric Pressure-Swirl Atomizer Floating Point Error
Matthew
MattDuff99 is on a distinguished road
I am currently attempting to simulate a pressure-swirl atomizer. I am using a simplified 2D axisymmetric model with the 'Axisymmetric Swirl' model included to simulate the swirling flow. I have calculated the radial and tangential velocities required of an equivalent annunar inlet to the flow through conservation of mass and angular momentum, and I am confident that I have these values correct.
My issue is that the swirling flow causes my residuals to diverge and eventually reach a floating point error, of which it says the specific cause cannot be identified. This was initially the case when I was modelling the full multiphase flow with the implicit unsteady solver. I thought it may have been a meshing or time step issue, but I was unable to solve it that way. I have also tried to use just water as the fluid in both implicit unsteady and steady state but even then the results diverge and eventually crash regardless of models, mesh, or time steps.
I have tried to follow all advice on other problems suffering from floating point error's but I believe mine is directly relating to the swirl and I have not been able to find any advice on this matter.
Here is a google drive link to a steady-state attempt at simulating this swirl:
https://drive.google.com/file/d/1gJT...ew?usp=sharing
If anyone could offer any assistance it would be greatly appreciated.
Thanks,
Matthew
MattDuff99 is offline   Reply With Quote
Old   October 19, 2021, 19:12
Matthew
Just some further information as I realise I may not have provided enough previously.
Boundary Conditions:
Inlet: Velocity Inlet with velocity components [0.0, -4.0971, 4.2259]
Outlet: Pressure Outlet with pressure = 101325pa
Axis: x-axis
The rest are walls with no-slip condition
Initial condition is specified as air with water flowing from inlet
Models:
Axisymmetric
Axisymmetric swirl
Cell quality remediation
Implicit Unsteady
K-omega turbulence
Multiphase
Segregated flow
SST
Turbulent
Volume of fluid
Multiphase interactions:
H20-Air - Surface Tension Modelling
H20-H20(vapour) - Cavitation (Schnerr-Sauer)
Mesh:
Polygonal Mesher
Prism Layer Mesher
Approximately 80,000 cells with local refinement particularly around the nozzle. I have attached a picture of the mesh at the nozzle to give an idea of the mesh.
Using a time-step of 5e-5s to test the flow but this diverges every time. I have also used the adaptive time-step model to keep the CFL numebr below 2 but this also diverged after around 3 hours of running and 40,000 iterations.
I am at a loss for where to go from here, I am not sure if the issue is related to the mesh or under-relaxation factors but any assistance would be appreciated.
Old   August 20, 2022, 08:54
Alexandre Felipe Medina Correa
LexMedina is on a distinguished road
Matt, have you found a solution? I am facing similar problems.
LexMedina is offline   Reply With Quote
axisymmetric swirl, floating point error, star ccm+
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 14:21
long error when using make-install SU2_AD. tomp1993 SU2 Installation 3 March 17, 2018 07:25
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
ParaView for OF-1.6-ext Chrisi1984 OpenFOAM Installation 0 December 31, 2010 07:42
