FSI with Morphing
Old   September 17, 2021, 12:54
Default FSI with Morphing
Tommaso M.
TommyM is on a distinguished road
Hi All,
I am modeling a fluid-structure interaction where the fluid causes the deformation of the solid, such deformation affects the flow field and the cycle is repeated.
Thus, it is necessary a mesh morphing to account for the change in the fluid domain shape.
I do not understand if STAR is able to perform the entire analysis internally.
I know this is possible via co-simulation (for example, with Abaqus), maybe it is possible to perform a co-simulation with STAR itself.
But is it possible to create a model that considers these features in a single simulation?
(I know STAR has the "two-way coupling" capability so I imagine it can do it, but I did not found anything on the guides about it).
Thanks for your attention,
Tommy
TommyM is offline   Reply With Quote
Old   September 19, 2021, 06:49
cwl
Chaotic Water
cwl is on a distinguished road
User Guide: Tutorials -> Solid Stress -> Fluid Structure Interaction: Vibrating Pipe
cwl is offline   Reply With Quote
Old   September 20, 2021, 09:39
Tommaso M.
Hi Chaotic Water,
thanks for your reply. Moreover, sorry, I should have looked at that tutorial better.
Since I am dealing with a FSI simulation, I am trying to understand which approach is the best one to study a dynamic analysis (something similar to this one: Tutorials > Coupling with CAE Codes > Abaqus Co-Simulation: Mechanical Coupling).
The possible methods I found are:
1) Co-simulation with external code (in my case, Abaqus).
2) Simulation entirely run in STAR-CCM+.
3) Co-simulation with STAR-CCM+.
I think the co-simulation with Abaqus could be the best choice since its FEM capabilities are better than STAR's. Is there a particular approach you suggest?
Thank you!
Tommy
Old   September 22, 2021, 11:13
Tommaso M.
Originally Posted by TommyM View Post
Hi Chaotic Water,
Thank you!
Tommy
Hi All,
I have been reading about this topic and I found the following conclusions:
1) Co-simulation with external code (Abaqus) has the advantage of using a high level FEM code to solve solid mechanics, thus it is recommended whenever the mechanical analysis is complex.
On the other hand, it requires an additional license and additional setup for the Abaqus settings.
2) Co-simulation with STAR-CCM+ has the only (I guess) advantage of splitting the time-scales, i.e. you can use a time-step size for fluid dynamics and another one for solid mechanics.
3) Simulation entirely run in STAR-CCM+ is good but its capabilities are lower than Abaqus' when it comes to FEM. Furthermore, shells cannot be used to simulate solid displacements.
Anyway, its settings are simpler due to the fact all the simulation is set in the same software.
These are my conclusions but if someone would add or correct something, please feel free to do that.
Tommy
Old   September 24, 2021, 01:56
cwl
Chaotic Water
Hi All,
From what I understand multiple (different) time scales which were introduced recently are available for fluid and solid (thermal) models - and for solid (stress) models as well.
fsi, fsi 2-way, morphing
FSI: How to transfer static pressure from fluent to ANSYS momo_sjx FLUENT 0 October 9, 2012 14:37
BCs in an FSI simulation of a flexble pipe vivekcfd OpenFOAM 10 January 8, 2010 05:14
fsi sun Siemens 8 January 20, 2009 00:17
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
FSI on a Rotating Structural Model drgolf CFX 9 August 30, 2007 13:08
