Condensation: temperature divergence
Old   August 25, 2021, 12:09
Default Condensation: temperature divergence
seunghyeon, yun
YOUNS is on a distinguished road
Hi
I'm working a condensation simulation.
There is solid in the center of the square duct.
The solid shape is just a cube and surface's temperature 25C.
Inlet condition is velocity inlet: 1 m/s, multi-gas(Air:0.8, Water:0.2).
Outlet condition is pressure outlet: species(composite), temp.(temp. in field function).
The surfaces of the solid has Fluid film(shell) and 25c on the surface of solid.
But, The solid region is empty.
Fluid film has multicomponent-liquid: H2O(water), Psat: Antoine eq.
My problem is Temperature divergence from nearby solid.
Data logging is it: Temperature limited to minimum value xxxx times on model part "Fluid".
How to solve this problem?
YOUNS is offline   Reply With Quote
Divergence detected in AMG solver: temperature mou FLUENT 3 April 9, 2024 01:51
Divergence detected in AMG solver. VOF. Mr.Mister Fluent Multiphase 4 September 25, 2023 08:10
Jet impingement cooling error - Divergence detected in AMG solver: temperature riquelme FLUENT 0 December 30, 2019 08:19
Two Phase Flow In Vertical Pipe stonepreston FLUENT 2 October 31, 2017 09:35
Error: Divergence detected in AMG solver: x-momentum/ epsilon/ temperature bubuchacha FLUENT 6 February 26, 2013 04:30
