August 23, 2021, 01:35 |
changing contact after meshing problem
Jeonglim Yoon
Hello. i used ansys fluent, but now using the star ccm+,
i studying some thin and very wide heat exchanging panel with ccm. For security reasons, i can't give you more details. Please understand. it may be similar to heat exchanger. my question is that before the meshing, is correct. but after meshing, changing incorrect. side face, bottom face are contacted. Is it because it is relatively wide compared to its thickness? i handle tolerance and tesselation(part import, imprint option). but it isn't work. i checked CAD Model, it was fine. can you help me? |
August 27, 2021, 03:23 |
Jeonglim Yoon
i found the solution. ha...
click the 'solution initialize' and checking the interface. |
contact, mesh, star ccm |
Problem with 'Mapped Face Meshing' | RobertW | FLUENT | 0 | November 19, 2016 15:39 |
[Gmsh] Vertex numbering is dense | KateEisenhower | OpenFOAM Meshing & Mesh Conversion | 7 | August 3, 2015 10:49 |
[ANSYS Meshing] Problem with meshing a complex Geometry (Hex) | fluent_beiyo | ANSYS Meshing & Geometry | 8 | April 26, 2014 04:55 |
[ICEM] Meshing problem in Formula one | Far | ANSYS Meshing & Geometry | 113 | April 23, 2013 12:36 |
FSI Mechnical Contact Problem in Labyrinth Seal Calculations | peterputer | CFX | 0 | September 18, 2012 15:59 |
