Implement field function with data from previous time steps as boundary condition
Old   August 20, 2021, 16:33
Default Implement field function with data from previous time steps as boundary condition
Faraam is on a distinguished road
I am trying to implement the attached function for the density as a boundary condition in a multi-component-liquid case. In the equation \dot{M} is the mass flow of component A, \Delta t the time step and V the volume.
My approach:
1. Field function rhoZero:
${TimeStep}/(${Volume}) * ${Boundary species flux}
(${Boundary species flux} is a Surface Integral Report with the boundary as input part)
2. Field function rhoT:
${rhoNull} + ${Historyofrho_0Sample1}
(${Historyofrho_0Sample1} is a field history of rhoZero with the boundary as input part, a sliding sample window size of 2, Trigger: time step, time-step frequency > frequency: 1; Start: 0; Enable stop: disabled; Stop: 0)
3. In order to implement the field functions 1 and 2 as a boundary condition (because only the specification of a mass fraction of the respective component at the interface is possible):
3.1 Field function wDispersed:
${rhoT} / ${Density}
3.2 Field function wConti:
${wDispers} / ${H*}
(where ${H*} is a constant)
When select field functino 3.1 and 3.2 as Species Mass Fraction and try to run the simulation I get the warning "Unable to find field function wConti on "NameOfBoundary". Please check that function is defined here."
Does anyone know where I'm making mistakes? Hope everything is understandable.
Faraam is offline   Reply With Quote
boundary conditions, field functions, field history, mass fractions
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
How to implement heat flux boundary condition as function of time baran_foam OpenFOAM Running, Solving & CFD 3 September 15, 2014 01:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
