Mesh Generation problem
Old   July 28, 2021, 09:55
Default Mesh Generation problem
Kelvin Eloho
Kelysamex is on a distinguished road
Hi everyone,
I initiated a mesh generation using Star-ccm+. The mesh generation keeps running forever and never completes. I believe the expected element count should not be that colossal. Because, I have generated meshes of above 250 million cells in the past. So, I have an idea of how long it could take. I am generating the mesh on 1024 processes CPU. Each core with 32GB RAM.
The output is as below before the mesh generation suspends (or keeps running forever):
Executing Mesh Operation Prop fluid mesh
Checking mesh-CAD association...done. Found 8 problems, all fixed.
Preparing surface for surface meshing in Parts:
finished preparing surface for surface meshing CPU Time: 0.26, Wall Time: 0.26, Memory: 3055.22 MB
I will appreciate if someone could help me with how to fix this. Or has anyone encountered similar problem?
Kelysamex is offline   Reply With Quote
Old   August 2, 2021, 09:35
Matt
fluid23 is on a distinguished road
How do you know your mesh is not too big? Have you tried making it very coarse?
fluid23 is offline   Reply With Quote
Old   August 6, 2021, 03:50
Kelvin Eloho
Hi, I later found out the problem was from the geometry. The surfaces had issues.
mesh generation problem, starccm+
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
[ICEM] Problem making structured mesh on a surface froztbear ANSYS Meshing & Geometry 4 November 10, 2011 09:52
[ICEM] Problem making structural mesh on a surface froztbear ANSYS Meshing & Geometry 1 November 10, 2011 09:52
Problem with mesh generation Nestor FLUENT 3 November 1, 2006 03:54
