Input Table as a Boundary Condition in Star CCM |
July 21, 2021, 17:06 |
Saurabh Chavan
Rep Power: 5 |
Hello everyone,
I am fairly new to using Star CCM+ and am having an issue while trying to put in a table (Time and Temperature columns) as a boundary condition on one surface in my model. I keep getting the error "Time table profile method: No time column found in table". I only have two columns in the table (input via a csv file) and the first column is titled "time". Can anyone help me with this. Thanks! |
July 21, 2021, 20:10 |
Lucky
Rep Power: 66 |
Go back to where you imported the table, in Tools=>Tables. Find your table. Check what is going on for Table: Time
If your csv is formatted the way Star expects the option will be greyed out. If not, then you should be able to select one of the two coumns. Make sure the correct column is selected. For example, you can also check under Table: Data that both columns are selectable. While you're at it, make sure Table: Data points to your temperature and not the time column. |
July 21, 2021, 20:25 |
Saurabh Chavan
Rep Power: 5 |
Thank you for replying. In Tools=>Tables, the option is greyed out. Also, under Table : Data both columns are selectable and I have selected the Temperature one.
One thing to notice is that when I load the Table, I get this message in the output. There is some character before 'time' which is not there in the csv file |
July 21, 2021, 20:27 |
Saurabh Chavan
Rep Power: 5 |
Output is here:
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 17, 2020 00:44 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
several fields modified by single boundary condition | schröder | OpenFOAM Programming & Development | 3 | April 21, 2015 06:09 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
External Radiation Boundary Condition (Two sided wall), Grid Interface | CFD XUE | FLUENT | 0 | July 8, 2010 07:49 |
