Pietro
Rep Power: 5 ![]() |
I am modeling an airplane wing on star-ccm for a fluid-structure interaction analysis. The question is: how do you remove the static load obtained once the steady solution is converged? The CAD geometry given is the one of the wing operating. But if you run FSI with such a geometry, it will deform and at operation it will be bending upwards, giving a wrong lift. Basically the load seen by the wing is the following: Load = steady load + unsteady load What I am aiming for is to do the following operation: Load_effective = (steady load + unsteady load) - steady load = unsteady load Any ideas how to do so? Pietro |
aeroelasticity, fluid-structure, steady load, unsteady load |
Static FSI with Compressible Flow (SU2 7.1.1) | sangeet | SU2 | 3 | April 4, 2021 17:28 |
Failure load in static structural analysis | sijusimon | Structural Mechanics | 3 | June 22, 2018 05:14 |
FSI analysis | Rana shaharyar | Main CFD Forum | 2 | May 16, 2017 15:14 |
How can I continue FSI analysis again? | ciftci.ibrahim | FLUENT | 1 | November 24, 2016 14:30 |
Two way Fsi Problem- Non linear problem | kmgraju | CFX | 4 | April 28, 2015 12:15 |
