June 30, 2021, 10:39 |
Control of inner iteration
Thomas
Hello everyone,
I am working on a coupling scheme between neutronic and thermohydraulic using starccm+ v2019.2. The fact is each physic is solved by an implicit scheme but the coupling between them is explicit so I have to use a very small time step. A solution consist in doing external iterations that means for a same time step, repeat an iteration but I didn't find anything in starccm+ to do so. Another solution could be possibly the control of inner iteration, like .getSimulationIterator().step(n) but I don't know if the object exists for a Macro. If anyone has already seen something like that and can answer me I would be very grateful. Thomas. |
June 30, 2021, 14:06 |
Matt
Rep Power: 18 |
It is not clear to me what question you are asking here. Can you clarify?
July 1, 2021, 03:58 |
Thomas
So I'll try to clarify. I am looking for something to repeat the same time step with the unsteady solver. (like saving all the fields calculated at time t=t_0+dt and go back to time t_0). One idea I have would be to stop the computation between inner iterations but I don't know if it is possible. Thx. |
July 1, 2021, 08:28 |
Rep Power: 7 |
Hi, I'm not sure if this helps, but you can run a specified number of iterations, e.g. 3, by writing
sim = getActiveSimulation(); sim.getSimulationIterator().iterate(3, true); Running three time steps instead could look like this: sim.getSimulationIterator().run(3, true); There's also the step() method you mentioned and to be honest I'm not quite sure how that behaves - for a transient simulation and if if you specify number of steps I'd guess it's the same as run()? |
coupling, inner iteration, macro |
Slow calculation time on CFD server | killian153 | Hardware | 4 | July 27, 2021 08:28 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
Radiation Modeling | Chris89 | CFX | 20 | August 14, 2014 08:51 |
Ansys CFX exited with return code 1. | dheelibun | CFX | 8 | May 7, 2014 08:21 |
Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
