June 7, 2021, 09:28 |
Data mapping with Adaptive Mesh Refinement
Fredrik Lundvall
Hi!
I am doing an aero-acoustic simulation running an LES with adaptive mesh refinement and a very fine mesh. I want to use the flow field data in a external software and want the file in Ensight Gold format with a constant mesh size (one .geo file). I use the data mapping to map the flow field on a coarser mesh, the problem occurs when it tries to data map after the adaptive mesh refinement (every 5th timestep). It looks fine before any mesh changes in the source mesh but after it, it fails. Do you have any ideas/suggestions on how I can get the export to work? Regards, Fredrik |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Mesh gets out of sync during parallel 2D adaptive mesh refinement | pjohannes183 | OpenFOAM Programming & Development | 0 | November 14, 2013 04:31 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
[Gmsh] Import gmsh msh to Foam | adorean | OpenFOAM Meshing & Mesh Conversion | 24 | April 27, 2005 08:19 |
