Exhaust Manifold simulation
Old   May 31, 2021, 12:32
Red face Exhaust Manifold simulation
Rohith Prakash
rohith0698 is on a distinguished road
I am given an exhaust manifold CAD. The task is about analysing the pressure drop and the thermal behaviour of the manifold.
Inputs 1) Mass flow rates of the inlet along with the static temperatures at the inlet runners
2) Outlet pressure value and the temperature at the outlet along with a convection medium heat transfer coefficient and ambient temperature.
Question
1) Do I need to change the initial conditions(I mean the static temperature) of the 2 continuums (solid and the fluid) or should I give the inlet temperature at the regions.
2) I have used a surface remember, tetrahedral mesh and a prism layer mesh. Is it okay ?
3) I have selected a 3-dimensional, gaseous steady state, turbulent coupled flow and a constant density model for the fluid and a 3 dimensional steady state solid with coupled solid energy and constant density for the solid continuum.
My values aren’t converging…. Where am I going wrong ?
Thanks in advance.
rohith0698 is offline   Reply With Quote
Old   June 5, 2021, 18:25
Vlad
DrDerpy13 is on a distinguished road
there is a tutorial in user guide which has a similar case to yours and it is explained step by step how to do both fluid flow and heat transfer. I think you can find it in the heat analysis section
DrDerpy13 is offline   Reply With Quote
Old   June 6, 2021, 13:27
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Some quick tips-
1. Go with polyhedral meshed for Fluid and Thin meshed for the solid
2. Try to maintain conformal contacts.
3. No need for coupled flow here, go with segregated flow first.
4. Model density using Sutherland's law (take ideal gas)
5. Initial conditions are just for initial guess. So to avoid divergence issues, we try to take initial conditions close to our boundary conditions
6. Apply mass flow in, temperature for BCs.
7. Hope you are using natural convection HTC at outer solid surfaces.
ashokac7 is offline   Reply With Quote
Exhaust pipe simulation itsme_kit Main CFD Forum 0 September 17, 2013 04:41
exhaust manifold flow and heat transfer simulation jai CFX 4 September 6, 2013 16:52
AVL fire Exhaust manifold Simulation mohsenfjs Main CFD Forum 0 May 15, 2010 12:51
Point the noob in the right way - IC Engine exhaust simulation AndreF OpenFOAM Running, Solving & CFD 12 December 16, 2009 06:04
exhaust gas simulation jai CFX 1 November 23, 2009 05:23
