Acquiring the vectored thrust of an EDF rocket |
Johan M
Rep Power: 5 ![]() |
Dear All,
I trust everyone is keeping well ![]() I am part of group that is making an electric ducted fan rocket. We are using aerofoil vanes to redirect the thrust. I would like to calculate the redirected thrust force, and tabulate it against various angles of attack. The 2-D setup done in Star CCM+ is seen in the attached image. The block on the left contains a segment of the rocket that has a known air mass flowrate inlet and walls. The block on the right represents the surrounding atmosphere. I saw a post on another forum were a user suggested placing a plane under a copter to measure the thrust force on it. I would like to know if it is possible to insert a ''pseudo plane'' perpendicular to the redirected thrust force, and then run a force report along a vector in that direction. Or alternatively if there is a simpler approach using momentum equations that I may be overlooking. Kind Regards Johan M |
airflow, electric ducted fan, rocket, thrust force |
Thrust not up to the mark for rocket engine simulation. | adithyaG | FLUENT | 0 | November 5, 2020 21:18 |
Including Thrust (Rocket Exhaust) Forces in Fluent's 6-DOF Solver | jbo214 | FLUENT | 0 | November 14, 2019 12:57 |
Rocket thrust chamber - Doublet Impingement | Goky | FLUENT | 0 | December 16, 2017 00:20 |
Thrust vectoring of rocket nozzle by a jet tab | umesh k. | Fluent Multiphase | 0 | January 17, 2017 07:33 |
Calculating thrust for a rocket nozzle for a biphasic fluid | toniatop | CFX | 0 | January 17, 2013 19:15 |
