Fluid mixture enthalpy as a function of mass fraction
Old   May 12, 2021, 02:17
Default Fluid mixture enthalpy as a function of mass fraction
cwl
Chaotic Water
cwl is on a distinguished road
Hi everyone
I'm trying to think of modeling sulphuric acid dilution in water: the more water is added to the acid the more heat is generated.
Omitting the chemical mechanism - amount of heat released can be found using the enthalpy of mixing diagram as a function of concentration of water:
So i suppose the easiest way would be - if enthalpy of the fluid mixture (acid + water) could be defined as a function of mass fraction of components(s), but .. from what i've found - enthalpy can only depend of temeprature and pressure.
Any ideas on how to implement that or advices in general? - Or maybe my idea is incorrect in general.
cwl is offline   Reply With Quote
Old   May 12, 2021, 13:13
Matt
fluid23 is on a distinguished road
Would an energy source linked by field function to your mixing diagram be appropriate?
I don't do a lot of reacting flows, just trying to be helpful. What about the 'user defined reaction-rate source term'?
Let me know if I am underthinking this.
fluid23 is offline   Reply With Quote
Old   May 12, 2021, 23:52
cwl
Chaotic Water
Yes, fluid23, that was the first idea I had - and I also tried to implement approach described on Steve Portal ("An example of implementing the Enthalpy of Mixing"), but that article contains several mistakes (starting from incorrect units) and results in the article look ok only as a result of coincidence and the fact that gas mixture is considered, not fluid mixture.
I've corrected it, but honestly speaking I'm still facing heat imbalance problems with that approach.
I'm grateful for the reply anyway
Reacting flow was right next idea after the one described above, but ...
Briefly - chemical heat release rate can be described as rᵢ·hᵢ, where hᵢ - is some heat or enthalpy difference (no problem with that), while rᵢ - is a rate of change of species.
In case of "usual" reaction A + B → C + D (like 2·H₂ + O₂ → 2·H₂O) - A and B disappear and chemical terms are ok since rᵢ of reactants is non-zero.
But in case of "dilution" reaction (unless we go deep down to H⁺, H₃O and HSO4⁻ etc) in case of sulphuric acid we have ... H₂SO₄ + H₂O → H₂SO₄ + H₂O.
And thus rᵢ is .. zero, and so is the heat release %)
mass fraction of species Lilly FLUENT 5 March 13, 2022 18:52
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 18:22
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Overflow Error in Multiphase Modelling with Two Continuous Fluids ashtonJ CFX 6 August 11, 2014 15:32
CFX Solver Memory Error mike CFX 1 March 19, 2008 08:22
