Flexibility to oscillating foil
Old   May 9, 2021, 09:15
Default Flexibility to oscillating foil
Vignesh
Vignesh D is on a distinguished road
Hi everyone,
I am doing research in the field of oscillating foil which will propel the ship. I am using STAR-CCM+. I am able to give the motion to foil when it is a rigid one, using overset mesh. Now I want to introduce flexibility to the foil.
Please guide me how to do this. Thanks in advance.
Vignesh D is offline   Reply With Quote
Old   May 12, 2021, 14:24
Joseph
jseamon1 is on a distinguished road
Are you looking to self-prescribe the flexibility/deformation of the foil? If so, there is a tutorial in the tutorial guide which goes through deformation of a oscillating pipe that might be of use. It's under tutorials -> Solid Stress -> Fluid-Structure Interaction: Vibrating Pipe. Hope this helps!
jseamon1 is offline   Reply With Quote
Old   May 13, 2021, 11:26
Vignesh
Hi Joseph,
Thanks for the reply.
I am doing open water study with the foil alone. So, the input is given as a rotation to foil. My foil should deform while fluid is exerting force on it.
Old   May 26, 2021, 05:43
Yazus is on a distinguished road
Hey,
First thing first, check that both domain are correctly defined and that Star CCM+ does understand that the propeller and the fluid are in contact. To be sure, I would suggest you substract the propeller from the fluid domain and check the "contact" node once you imported the geometry.
Then, you can define a new continuum for the solid physics, activate the "Solid Stress" model with a linear isotropic law for example.
You should activate the "Fluid Structure Interaction" option and then indicate where are the matching boundaries, called "Interfaces". This function allow the program to compute solid displacements from fluid loads and vice-versa.
I suggest you give a look at StarCCM's tutorials, they are really instructive :
Help -> SimCenter StarCCM+ -> Simulating Physics -> Solid Stress -> Modelling FSI.
Yazus is offline   Reply With Quote
Drag Coefficient Gradient: 0 in 2d adjoint optimization tomp1993 SU2 Shape Design 11 August 1, 2019 16:14
Implementing Flexibility to the oscillating foil antieskmartin STAR-CCM+ 1 May 9, 2018 13:47
What is "Lock-In" in oscillating cylinder problem? 9mile Main CFD Forum 0 June 3, 2015 10:57
Problem with 2-d oscillating foil cib10166 FLUENT 1 April 7, 2014 15:03
Oscillating Foil - 2 domains issue adubois FLUENT 0 February 13, 2014 03:44
