March 26, 2021, 09:59 |
Using Report values as boundary values
Rep Power: 6 |
Hi everyone,
i have to set up a simulation with pressure outlets. The mass flow through these outlets is varying and unknown quantitatively. During the calculation, a report records the mass flow. The scalar value of the mass flow should serve as a value for a mass flow inlet at another position (but same fluid region) simultaneously during the calculation. Do any of you see an easier way to use the Mass flow report for a boundary condition other than via a user-coded boundary? Thanks a lot in advance! |
March 29, 2021, 02:30 |
#2 | |
Chaotic Water
Rep Power: 18 |
report, user-coded, varying boundary |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 06:53 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 12:19 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 07:28 |
Numerical errors in nested domain with pre-calculated boundary values | Arnoldinho | OpenFOAM Running, Solving & CFD | 3 | April 4, 2012 11:31 |
