March 15, 2021, 12:48 |
Deformed Mesh in DFBI
Will Crawford-Jones
Rep Power: 5 |
I'm trying to model a sphere rolling over some other spheres in open channel flow (see attached image "Geometry_Scene_1_image_1.500000e-03.png"). I have set up a DFBI model- under [tools < motions] I have included DFBI Rotation and Translation (which enables 6 DOF movement of a body) and DFBI Morphing (which I understand is for the morphing of the mesh). I have set up a contact coupling such that the sphere does not 'move into' the lower spheres and cause an error. Firstly, I ran the simulation and noticed that the cells did not seem to get refined and between the moving sphere and the left base sphere became stretched (see attached image "Geometry_Scene_1_image_2.000000e-03.png"- they progressively became more stretched than this). Anyway, I eventually encountered a negative cell volume error. I then explored the Adaptive Mesh feature and set Adaptation Requests to various mesh metrics (cell quality, aspect ratio etc). However, the cells continue to stretched and I encounter a negative cell volume error even quicker than before. My question is: how do I set up an adaptive mesh for my case of a translating and rotating sphere; as the sphere moves away from the bottom left sphere I would need new cells to be created rather than stretched. Also, I would need the cells downstream to be removed as they become compressed. At the moment, cells are stretching and I am getting negative cell volume errors as well. Thanks a lot Will |
March 18, 2021, 04:54 |
Will Crawford-Jones
Rep Power: 5 |
Anyone have any ideas with this please? Any help you can give would be great Thank you! |
6 dof, dfbi morphing, open channel flow |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
3D Hybrid Mesh Errors | DarrenC | ANSYS Meshing & Geometry | 11 | August 5, 2013 06:42 |
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation | tommymoose | ANSYS Meshing & Geometry | 48 | April 15, 2013 04:24 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
