Prism layers retraction around sharp edges
Old   February 15, 2021, 05:07
Default Prism layers retraction around sharp edges
Korimbo is on a distinguished road
I have the geometry that you see in the image. Where the mesh gets refined, the prism layer thickness retracts. Does anyone have any idea how i can fix that? I need a constant prism layer thickness around the whole surface. I tried changing a lot of parameters but nothing has worked so far.
Thank you in advance.
Korimbo is offline   Reply With Quote
Old   February 24, 2021, 07:44
Default user defined prism layer parameters
diickhead is on a distinguished road
hi, maybe you can try to toggle the check box in your refinement operations, where you can find settings about prism layer thickness.
diickhead is offline   Reply With Quote
boundary layer, prism layer, prisms, retraction
[snappyHexMesh] snappyHexMesh stuck when snap is turned on yukuns OpenFOAM Meshing & Mesh Conversion 3 February 2, 2021 14:05
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
[ICEM] How to create prism layers on sharp trailing edges in ICEM CFD (3D Tetra Mesh)? waseeqsiddiqui ANSYS Meshing & Geometry 15 January 30, 2019 11:59
[snappyHexMesh] Problem with prism layers at corner edges Fauster OpenFOAM Meshing & Mesh Conversion 1 September 30, 2016 01:25
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
