January 26, 2021, 19:06 |
Conformal mesh between two Directed mesh
Rep Power: 6 |
Hello STAR-CCM+ users,
I have a geometry which consist of a cylinder divided in three parts along its length. Part 1: normal cylinder Part 2: hollow cylinder (the fluid moves through a ring shape region) Part 3: normal cylinder Does anyone knows how to get a mesh created with the Directed mesh tool that is conformal at both interfaces? I can't mesh the three parts in one operation. I can mesh Part 1 and 2 together, and I have to mesh Part 3 in a different operation. This results in non-conformal mesh between 2 and 3. Taking the source mesh from an existing mesh doesn't work. I could do an Automated mesh across the 3 parts but I need the cells in part 2 to be long in the axial direction. Automated mesh cannot do that or I don't know how. I'm assuming there must be a way to take the surface mesh between 1 and 2 and force that on the face between 2 and 3 when I mesh part 3. Any help would be appreciated. |
January 27, 2021, 01:55 |
Ping
Rep Power: 20 |
it's possible in directed but too hard to describe and not at all worth your effort
i suggest automated using the poly mesher since it will give you conformal mesh at the interfaces if you set it up correctly in 3d-cad with imprinting and parts and get the contacts correctly. then enable the thin mesher to create the axial cells in the hollow are - might need a few trial meshes to get the settings working. |
January 27, 2021, 05:30 |
Chaotic Water
Rep Power: 18 |
If you imprint contacting surfaces and create periodic "apply to mesh only" contact (not interface) between parts 1 and 3, use surfaces on the contact side as source for direct mesher .. maybe directed mesher will produce conformal mesh - and thus mesh for part 2 can be swept in directed mesher using contacting mesh (from part 1 or 3).
But in general ping is absoluterly right - directed mesher is not worth it. I'd add - that it is still full of bugs and sucks a lot in general. |
foam-extend-4.1 release | hjasak | OpenFOAM Announcements from Other Sources | 19 | July 16, 2021 05:02 |
[ANSYS Meshing] Relation between conformal mesh and mesh connexions in Ansys meshing | Manel | ANSYS Meshing & Geometry | 0 | December 26, 2019 13:16 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
