January 10, 2021, 12:45 |
Flow over an Airfoil
Rep Power: 5 |
Hey all, it's me again.. I am currently working on simulating the flow around a NACA0012 profile. My current problem is that I get very high deviations (about 30%) in the simulated drag coefficient compared to the one from the experiment (NACA Report 460). The lift coefficient on the other hand has a much better value with 1% deviation.
About the Set up: - automated poly mesh - Fluid temperature - SST K Omega - AoA ~ 11° The experiments were performed at Re = 3.2E6 and my simulation has a Reynods number of 7.8E5. Is this the reason or does the comparison make sense because of the different Reynolds numbers? Do you have any suggestion what I should look at again? Many thanks in advance! |
January 31, 2021, 18:11 |
Chris
Rep Power: 7 |
Hey, if you're still having problems try the gamma transition model with a turbulence intensity of 0.001.
With the higher Reynolds number you should be getting a lower drag coefficient, but without the transition model it effectively models the whole boundary layer as turbulent thus overpredicting the drag. |
February 5, 2021, 05:35 |
Rep Power: 5 |
Thank you very much for your answer!
I tried it, but it didn't really change anything in my case. I then removed it to save computational effort. I tried it with a larger domain and looked again for experimental values that fit better in terms of the Reynolds number and are documented in a table. Now it is OK |
February 6, 2021, 05:05 |
#4 | |
Lefteris
Rep Power: 15 |
Secondly, the boundary layer in the wind tunnel test is possibly tripped. But good luck trying to match the onset of transition if you use a transition model. In my opinion you'll be better off with a fully turbulent boundary layer right from the start. Also, as the name of the report suggests, the tests have been done in a variable density wind tunnel. So make sure you replicate the conditions. That should get you going.
Lefteris |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
flow over an airfoil 3d ( Geometry on icem cfd ) | dfmona | Main CFD Forum | 0 | April 13, 2010 23:32 |
problem in modeling flow over a 3d airfoil | guess | Main CFD Forum | 8 | March 20, 2010 13:54 |
Airfoil conditions for unsteady flow | Dave | Main CFD Forum | 3 | April 24, 2008 17:11 |
Simulating flow past airfoil with different AOA | Quarkz | Main CFD Forum | 2 | January 6, 2006 10:56 |
