December 24, 2020, 04:36 |
Design Manager, STAR CCM+ & NX
Hello everyone, I'm trying to do a design manager project to work on STARCCM+, and as a simple test i'm simulating the flow in a pipe, with the draft angle of the pipe as a parameter.
If I change the parameter in the simulation, I can update the geometry and then the solver runs perfectly, but If I try to sweep the parameter , every design fails except for the base desing, which is the current one in the simulation. I'm using Windows, and i've connected NX to Star so that the simulation is started from NX, with the part as a client model. The error that I get is that the Star cad document is not valid. |
December 27, 2020, 03:36 |
Ping
Rep Power: 20 |
there is a setting in design manager to save all the files for each run then you will be able to open some of the problem .sims in star and hopefully see what has gone wrong - probably in the geometry or meshing
July 11, 2024, 09:38 |
Lihu
Hello, I have the same problem, have you solved it?
design manager, siemens nx, star ccm+ |
problem when imported geometry from 3D CAD to star ccm, | TAREK GANAT | STAR-CCM+ | 1 | May 21, 2013 23:15 |
[Commercial meshers] Using starToFoam | clo | OpenFOAM Meshing & Mesh Conversion | 33 | September 26, 2012 05:04 |
star design - to model heat transfer | gagi | Main CFD Forum | 0 | November 11, 2011 02:41 |
[Other] StarToFoam error | Kart | OpenFOAM Meshing & Mesh Conversion | 1 | February 4, 2010 05:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 05:15 |
