Flow visualization at overset mesh interface
Old   December 22, 2020, 22:04
Default Flow visualization at overset mesh interface
Jim
haizhou0410 is on a distinguished road
Hi everyone,
I use star-ccm+ overset mesh method to do flow simulations with motions. I found that the flow e.g. vorticity plot at the overset mesh interface has some problems. It seems that not all unwanted cells are blanked. I use tecplot value blanking and use the "blank entire cells when 'primary value is blanked' "option and blanked the cells when overset cell status equal to 1, -1, -2 which corresponding to inactive, acceptor that is used as donor and acceptor respectively. But it still has problems with the interface which are shown in the picture. Does anyone know what can I do with this? Thank you very much in advance!
haizhou0410 is offline   Reply With Quote
Old   December 23, 2020, 12:04
Aleksandr
profi_star-ccm+ is on a distinguished road
I could not find your error. I'm going to study again.
profi_star-ccm+ is offline   Reply With Quote
Old   December 25, 2020, 02:57
Jim
You have a nice flow field plot. I can't see any error that appeared in my case. How did you make this happen? Have you tried to plot this in tecplot? Thank you! Btw, nice model.
Attachment 81737
Attachment 81738
Attachment 81739
Old   December 27, 2020, 03:32
Ping
ping is on a distinguished road
have you looked at the equivalent scenes in star using its post processing which is designed to automatically deal with the display of overset mesh results?
if they look correct then why go to tecplot anyway- what does it have that star can't do for general p.p.?
ping is offline   Reply With Quote
blank, interface, overset, star-ccm+
objects oscillate at high speed causing collapse in Dynamic mesh and overset mesh ca insane OpenFOAM Running, Solving & CFD 0 May 17, 2020 23:35
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
How to make a smooth interface for multiphase flow with dynamic mesh? aegean333 OpenFOAM Programming & Development 0 May 10, 2013 06:34
