minimum Z coordinate given the X, Y coordinates |
December 7, 2020, 08:14 |
In a 3D model (in STAR CCM+) I need to extract the minimum Z coordinate given the X, Y coordinates.
For example, in the point (0,0) I would like to know the minimum Z coordinate. Thanks in advance |
December 7, 2020, 08:58 |
Matt
Rep Power: 18 |
minimum report of a position threshold
although that will return cell center values, not the furthest edge |
December 9, 2020, 11:28 |
thanks for the reply but it's probably not what I need ...
I'm looking for a procedure (with field function) with a surface and X, Y coordinates as input and Z coordinate as output |
December 9, 2020, 21:33 |
Sebastian Engel
Rep Power: 21 |
Make a scalar field function with $Postion[2] as input. Then a minimum report on your surface part with that user field function.
I am not sure whether Centroid is a better option here. Consult the manual regarding that question. You should be able to get that report's value as field function as well--in order to use it in another function. |
cfd, extract data, extract point, positions, star ccm |
Issue with Coordinate Systems and U Velocity on CFD-Post | CiaranStubbsParker | ANSYS | 2 | July 18, 2022 12:50 |
Problem with coordinate selection in ansys static structural | ngoc_tran_bao | ANSYS | 0 | November 25, 2020 04:27 |
Getting the coordinates of a local coordinate system | Oculosdegrau | STAR-CCM+ | 5 | October 26, 2020 10:06 |
[Scripting]: How to get the coordinates of a 2D airfoil @ different angles of attack? | CfdIntro | Main CFD Forum | 2 | December 12, 2017 10:23 |
Beginner help, coordinate udf with output file | nb92 | Fluent UDF and Scheme Programming | 0 | March 20, 2014 04:16 |
