Mass Averaging on meridional slices of a plane |
November 26, 2020, 10:59 |
Quinn
I am simulating a stator blade of a turbine and I am attempting to get pitchwise mass averaged data against span at a sectional plane at the exit of the stator. I have not been able to separate the plane into pitchwise slices in order to mass average, if this is possible I would be glad to know. I am using the csavg function to average scalars on a defined cylindrical coordinate system. The goal is to calculate the mass flux for each slice, multiply that by the scalar function, and then normalise by the total mass flux to get an approximate mass flow average. My problem is that I can't get a meridional average of the radial or axial velocity using the csavg function. Does anyone know how to do this or a better method of pitchwise mass averaging on a plane. Thank you MeasurementPlane.PNG |
average, cfd, post processing, turbomachinery |
DPMFoam - Serious Error --particle-laden flow in simple geometric config | benz25 | OpenFOAM Running, Solving & CFD | 27 | December 19, 2017 20:47 |
Mass Flow rate through a plane | titio | OpenFOAM Post-Processing | 9 | August 22, 2017 03:46 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Calculation of mass flow rate through a plane | titio | OpenFOAM Post-Processing | 2 | September 28, 2010 00:28 |
MERIDIONAL PLANE | Josh | FLUENT | 0 | July 7, 2007 11:10 |
