November 26, 2020, 05:56 |
Parts Operations - Extract Volume
Chaotic Water
Rep Power: 18 |
Good day everyone.
Is there a way to extract internal flow volume easily and fast - in case of two pipes placed inside a larger pipe using Parts Operations (Fill Holes, Imprint, Extract Volume etc)? The problem is that - depending on preceeding Imprint operations - Extract Volume either cannot find "topological region attached to selected surfaces", or ignores the pipe which is partially outside. And also result of Fill Holes (hole cap) cannot be target for Subtract to make holes in it. One of small pipes begins starting the same surface as the large pipe, another is partially outside. There should be some elegant way to do that - without breeding a huge zoo of intermediate part results of numerous unite and subtract operations. |
[Other] Space claim - Volume extract issue | Joćo Silva | ANSYS Meshing & Geometry | 1 | February 23, 2024 08:40 |
[Other] Ansys SpaceClaim Volume Extract Issue | openAC | ANSYS Meshing & Geometry | 6 | January 26, 2023 04:35 |
[blockMesh] edges not aligned with or perpendicular to non-empty directions | ynos | OpenFOAM Meshing & Mesh Conversion | 6 | March 26, 2020 15:02 |
Free surface issues with interDyMFoam for hydroturbine | oumnion | OpenFOAM Running, Solving & CFD | 0 | October 6, 2017 14:05 |
How to extract an internal volume in star ccm? | itsme_kit | Siemens | 11 | February 16, 2012 13:39 |
