rotating fan
Old   November 24, 2020, 10:38
Default rotating fan
Anthony
won0726 is on a distinguished road
Hi, I am a total beginner of using star ccm+ and I would like to get some help.
I followed the tutorial that is posted online/youtube that shows how to run the simulation, and I want to know the pressure difference between the inlet and outlet. So far, I got the area averaged inlet pressure, but my area averaged outlet pressure is constant 0. Thanks in advance.
Attaching the youtube site for reference.
https://www.youtube.com/watch?v=KvQc..._channel=Howto
won0726 is offline   Reply With Quote
Old   November 24, 2020, 12:38
Matt
fluid23 is on a distinguished road
First of all, I don't think that tutorial has a report for average outlet pressure. However, it makes sense for a report placed on a boundary condition to return the target value/setting.
The outlet is a pressure outlet, with 0 gauge pressure (unless you changed it). You are telling the solver that the pressure at this plane is always 0 so that it can bound the problem and find a solution.
At the velocity inlet, you are specifying velocity rather than pressure and would get a similar result for area averaged inlet velocity.
fluid23 is offline   Reply With Quote
Old   November 24, 2020, 13:23
cwl
Chaotic Water
cwl is on a distinguished road
Reports -> Pressure Drop.
cwl is offline   Reply With Quote
Old   November 26, 2020, 08:20
Anthony
Thanks for the reply. So in order to find the outlet pressure, do i have to change the gauge pressure which is 0? From the region - fluid-boundaries-pressure-physical values-pressure is at a constant 0 Pa, do i have to change the physics condition?
Old   November 26, 2020, 08:22
cwl
Chaotic Water
I'm afraid - you have to read a bit about what pressure first.
Old   November 26, 2020, 08:24
Anthony
Thanks for the reply. I tried using the pressure drop. So the high pressure would the 2 interfaces from the fluid:inlet and the low pressure would the fluidressure which is the boundary?
Old   November 26, 2020, 08:29
Anthony
Sorry but can you be a bit more specific?
pressure, rotating fan
Simulate rotating Fan using no MRF federernadal Main CFD Forum 2 May 3, 2018 01:11
Best software for centrifugal fan (rotating geometry) simulation DRoam Main CFD Forum 0 November 18, 2016 17:12
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 05:23
Interpreting streamlines of a rotating fan. danbence Visualization & Post-Processing 1 April 8, 2014 11:13
axial flow in counter rotating ducted fan Vishu FLUENT 4 January 13, 2004 18:52
