Parallel cylinders in contact
Old   November 19, 2020, 16:33
Default Parallel cylinders in contact
Chris Bailey
NotOsborneReynolds is on a distinguished road
What's the recommended approach for modeling cases where there are cylindrical objects that are parallel and are touching? Common physically, but the mathematical model is that they have line contact and vanishing separation approaching the contact. Numerical methods don't like singularities generally.
I have one case where the cylinders are solids in external contact, a bundle of rods tied together. I have another case where a smaller solid cylinder is inside a larger tube, so a rod lying in and supported by a pipe (cylinder diameter is maybe 0.9 of the pipe ID).
Does everybody normally just sketch it up, hold their nose, and hit go? Or is there something more... I dunno, elegant? respectable maybe? Use some solid deformation analysis to figure a reasonable finite width stripe of contact?
Thank you!
NotOsborneReynolds is offline   Reply With Quote
Old   November 25, 2020, 12:05
Sebastian Engel
bluebase will become famous soon enough
Originally Posted by NotOsborneReynolds View Post
sketch it up
A sketch could help to understand what you actually want to do. Are you interested into some bearing simulation, or do you just happen to have circular geometries in your domain and are interested in flow around such geometries?
bluebase is offline   Reply With Quote
Old   November 30, 2020, 14:45
Chris Bailey
[IMG]file:///A:/IllustrationForPosting.png[/IMG]
Old   November 30, 2020, 14:50
Chris Bailey
Great, that didn't work. I take it I have to find a web site for hosting images before I can post a sketch here. Will go off and search for one, but meanwhile...
I have several cases but the most urgent is this: a jacketed cable with multiple straight (untwisted) wires inside. At a glance you might mistake it for Ethernet cable. The wires touch each other, and the jacket touches the wires on the outside of the bunch. I need to estimate how the wires heat up as the outside of the jacket is exposed to high temperature. I am analyzing it as a 2D domain. It may be sufficient to only simulate the conductive transfer from part to part, but it the result is close to our go/nogo condition I may have to add the small air spaces as well as radiation transfer.
Old   November 30, 2020, 14:55
Chris Bailey
Old   November 30, 2020, 14:57
Chris Bailey
Aw, heck. What's the trick? I posted my image publicly on imgur and put the url into the "Insert Image" dialog, but still nothing. How do I post an image?
Old   November 30, 2020, 15:06
Chris Bailey
I hope you can use the text of the URL to see the 2D sketch:
https://imgur.com/gallery/VMwe3ho
My construction is a cable with six wires of nearly the same size. There are more details but they're not relevant to my question.
The circles represent wires that are in contact with one another. I think mathematically they touch at a single point in the sketch, or in 3D they touch along a line. If we are talking mathematical idealizations in the sketch, there is a singularity at the contact point, which numerical methods struggle with. In the red shaded area (which I shaded in MS Paint), there are three sharp edges which get infinitely thin as we approach the contact point. Likewise in the green area, with two infinitely thin edges as we approach the tangency point of the jacket. Also, do the red and green areas touch each other? The distance between them is zero or infinitely small.
I'm trying stuff and it may go well, but even I think what I'm asking it to do is not a well posed question. What is the best way to do sims with these kinds of singularities in the problem definition?
simpleFoam parallel AndrewMortimer OpenFOAM Running, Solving & CFD 12 August 7, 2015 19:45
[solidMechanics] solidMechanics gear contact in rotation nlc OpenFOAM CC Toolkits for Fluid-Structure Interaction 3 January 11, 2015 07:41
dynamic contact angle / contact line velocity ThomasN CFX 6 September 23, 2014 07:07
simpleFoam in parallel issue plucas OpenFOAM Running, Solving & CFD 3 July 17, 2013 12:30
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
