How to run a simulation with 2 different fluids? |
November 19, 2020, 11:16 |
ONTARIO
I have a Y channel, and I would like to run a simulation with 2 different fluids. I The Y channel has 2 inlets, I would like each inlet to have its own specific fluid.
I have created my channel and meshed it, I am not sure how to proceed. |
November 23, 2020, 04:59 |
Marco Riedel
Rep Power: 15 |
In Continua - Physics choose an appropriate model (multiphase flow or whatever). Then you can set the composite at each inlet boundaries node (under regions).
November 23, 2020, 11:51 |
#3 | |
Madrigal
Rep Power: 5 |
2 Fluid like what? If you have only gas so you should to choice multicomponent gas... if you have only liquids so you should to choice multicomponent liquid... if you want to mixture gas with liquids its depend or what you want.. what you want to simulate? I think i can help you ;-). good bye |
How to run multiple cycle pulsetile flow simulation in Ansys fluent using UDF code? | Md Al Amin Sheikh | Fluent UDF and Scheme Programming | 4 | January 28, 2020 11:55 |
How to Run Unsteady Simulation in Star CCM+? | Andi_Didi | STAR-CCM+ | 4 | November 13, 2017 01:41 |
Transient run continues from last time (when startover is desired) | bongbang | CFX | 2 | March 22, 2015 23:05 |
Shall I leave one core free when I run CFD simulation? | Pierre1 | Main CFD Forum | 1 | March 12, 2015 04:46 |
Procedure to run unsteady simulation? | STN | Main CFD Forum | 2 | February 16, 2002 04:37 |
