November 18, 2020, 16:52 |
Turbomachinery Interface
Daniel Campbell
Rep Power: 5 |
Hi all,
I am trying to run an unsteady for a turbomachinery simulation. At the moment I am using a mixing plane interface between the stator and rotor. However, this is only appropriate for steady simulations. What type of interface would you recommend to use instead? Any help would be greatly appreciated. |
November 25, 2020, 16:09 |
Ping
Rep Power: 20 |
just a normal in-place internal interface is all you need since you dont need the averaging that a mixing plane does when you are running full 360 degree geometry on either side of the interface and the rotor is actually moving each time step, as opposed to a moving reference frame sector geometry
Table bounds warnings at: END OF TIME STEP | CFXer | CFX | 4 | July 16, 2020 23:44 |
Can I achieve better convergence? | sheaker | CFX | 12 | September 19, 2019 15:36 |
Turbomachinery Mass imbalance | sheaker | CFX | 12 | September 5, 2019 08:09 |
My radial inflow turbine | Abo Anas | CFX | 27 | May 11, 2018 01:44 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
