Segregated Energy Solver - floating point exception |
October 24, 2020, 17:50 |
Lumi
I have a car and would like to calculate the heat transfer at the brakes. The model has the following settings: URANS, Realizable k-eps, Segregated flow + energy, high y+ wall treatment. The turbulence and mesh settings are given and I am not allowed to change them. The calculation stops after 4 steps with the output "Maximum Temperature limited to 1000 on n faces..." and "Floating Point Exception, Context: KeTurbSolver." Are there special solver settings, that could solve my problem? Without the energy input, everything was fine and it did converge. Thank you very much! |
floating point exception, k-epsilon, segregated energy |
floating point exception | ctmagic | Fluent UDF and Scheme Programming | 3 | March 9, 2021 20:52 |
[ANSYS Meshing] Help with element size | sandri_92 | ANSYS Meshing & Geometry | 14 | November 14, 2018 08:54 |
Floating Point Error Segregated flow solver | willful | STAR-CCM+ | 2 | May 13, 2016 15:36 |
A floating point exception has occurred: floating point exception [Overflow]. | starlight | STAR-CCM+ | 4 | May 4, 2016 10:08 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 04:44 |
