October 13, 2020, 10:48 |
2D Mesh generation warning
Yunus Aysan
Rep Power: 6 |
I am meshing a pipe which I have constructed in 2D. The pipe length is 20m. I extended the pipe length so it was 100m but now I get the following error message. mesh-error.JPG I increased the base size from 0.01m to 0.02m and the automated meshing sequence completed. However, I wanted to keep the same mesh as before so I know the change in output is due to the length change and not a combination of the mesh and the length change. Does anyone know what is causing this error, or the appropriate steps required to remedy the issue? Thanks! Last edited by Y27; October 13, 2020 at 10:50. Reason: invalid attachment |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
[mesh manipulation] refineMesh Error | mohsen.boojari | OpenFOAM Meshing & Mesh Conversion | 3 | March 1, 2018 22:07 |
using METIS functions in fortran | dokeun | Main CFD Forum | 7 | January 29, 2013 04:06 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
