Help Modelling Motion of Propeller Attached to Body (+ Boolean)
Old   September 11, 2020, 21:43
Question Help Modelling Motion of Propeller Attached to Body (+ Boolean)
3liminate is on a distinguished road
I'm wanting some help please with modelling a propeller using a rotation reference frame.
I currently have three parts (Part 1 = Fuselage Body with Propeller/Spinner, Part 2 = Wind Tunnel (Rectangular Prism), Part 3 = Cylinder around propeller [to be used for moving reference frame]).
How do I use the Boolean Subtract feature to correctly set up the model in terms of input and target parts? I currently have the wind tunnel domain set up as Part 1 and Part 2 being the Input, and Part 2 as Target. Now when I want to model motion, I'm unsure of how to set up Part 3 Correctly. Is it fine that the Propeller and Spinner are attached to the fuselage body as one part (Party 1), or must they be split up separately as another... e.g. part 4?
Thank you so much.
3liminate is offline   Reply With Quote
Old   September 12, 2020, 02:19
cwl
Chaotic Water
cwl is on a distinguished road
I'm pretty sure - following tutorials from the User Guide would help you a lot:
page 10021 - Moving Reference Frames: Rotating Fan
page 10054 - Rigid Body Motion: Rotating Fan
page 10117 - Moving Reference Frames: Marine Propeller in Open Water
cwl is offline   Reply With Quote
Old   September 12, 2020, 03:18
Thanks for the reply cwl,
Yes, I've gone through the tutes and understand the process. What I'm stuck with is how I should make the domains. For example, in the Open water propeller, they have the rotating region as the propeller, spinner and cylindrical reference frame. But there's no mention of whether they used a boolean subtract to position it in the domain or how to set up the initial parts. That's what I don't understand.
boolean subtract, input, motion, parts, reference frame motion
dynamicFvMesh - tabulated motion of a solid body + mesh morphing HendrikW OpenFOAM Pre-Processing 3 December 3, 2019 03:05
Fluid Domain moving with Rigid body Lloyd Sullivan CFX 3 August 17, 2018 10:58
trying to write a UDF for rigid body motion niteshrajput Fluent UDF and Scheme Programming 4 December 17, 2014 01:29
Rigid body motion on transient fluent mrf ghost82 EnSight 4 September 6, 2014 12:24
Rigid body motion error when restarting a terminated FSI simulation lingdeer ANSYS 1 May 19, 2013 02:40
