August 26, 2020, 03:57 |
nozzle thrust issue
huang,wei-hsin
Rep Power: 6 |
https://i.imgur.com/o0WgnTu.jpg
Hello,I am doing the simulation of a 2D nozzle.As you can see in the picture, exit jet is curved by the second inject flow,so , there will be a curve angle. And there are some problems happened in "THRUST" evaluate: 1.Is build "probe" the proper method to calculate thrust? 2. How to get Fx and Fy?(calculate curved angle) PLS help me to check the procedure of parameter thrust. |
September 1, 2020, 08:28 |
Matt
Rep Power: 18 |
Your question is not totally clear, can you rephrase it? In general, to get forces you would select your wall boundaries as inputs to a force report (or force reports if you want different directions, x and y).
nozzle thrust |
kOmegaSST Boundary Conditions for Supersonic Nozzle | shang2 | OpenFOAM Running, Solving & CFD | 2 | September 17, 2018 13:06 |
3D Thrust Vectoring Nozzle rhoCentralFoam problem | AleQ95 | OpenFOAM Running, Solving & CFD | 1 | May 3, 2018 16:43 |
Issue: Nozzle Discharge Coefficient | LiamH | FLUENT | 3 | February 25, 2017 17:04 |
[ICEM] Troubleshooting Wall Inflation Issue for a 2D Nozzle | cfmontes | ANSYS Meshing & Geometry | 1 | May 14, 2015 18:13 |
C-D nozzle supersonic jet boundary | Gland | FLUENT | 4 | May 24, 2012 00:25 |
