To simulate lamp bulb effect using solar load model
Old   August 25, 2020, 23:10
Default To simulate lamp bulb effect using solar load model
Jinwon Seo
seojwceo is on a distinguished road
Hello.
I hope to simulate effect of IR bulb in chamber with solar load model.
If we use solar load model manually, we can get the uniform flux for computational domain.
But, I want to simulate effects to computational domain of distributed intensity of virtual IR bulb(lamp) from outside computational domain.
How can i do this modeling? help me~
seojwceo is offline   Reply With Quote
Old   September 4, 2020, 06:08
Ping
ping is on a distinguished road
it is not clear what you are wanting to do so explain in more detail and maybe with a diagram.
do you really need the solar model? Could you instead use hot objects to represent the bulbs and use the s2s radiation model and you would have a larger computational domain to include your bulbs with a low number of cells since ray tracing is the main factor and volume cell size has no effect on its solver.
ping is offline   Reply With Quote
Old   May 16, 2022, 08:25
kerencostley
kerencostley is on a distinguished road
You can also simulate it and make many different things, not only uniform flux. However, I still don’t understand some of the information you listed above. Because I truly don’t understand what you mean by simulating the effects of the computational domain of distributing the intensity of the virtual IR bulb from outside of the computational domain. I can tell you to try doing it using these lighting strips https://www.vont.com/product/smart-s...-strip-lights/. They might actually work really fine for your situation.
kerencostley is offline   Reply With Quote
distributed intensity, ir bulb lamp, solar load
Burning Velocity Model (BVM) to simulate pure premixed turbulent flame saad.akhtar312 CFX 2 April 29, 2024 18:50
A doubt about DO model, Solar calculator and Boundaries Conditions Helium FLUENT 0 May 22, 2019 13:00
Solar Model and irradiation AmmarFasih FLUENT 0 April 4, 2019 07:22
Turned on solar load model, but solar heat flux in the counter plot still remain 0? szhang FLUENT 0 December 1, 2018 12:43
How to simulate the eulerian multiphase model about particle jhlee9622 STAR-CCM+ 2 November 24, 2016 12:37
