Solution history
Old   August 8, 2020, 03:43
Default Solution history
cwl
Chaotic Water
cwl is on a distinguished road
Hi everyone
Let's say - I'm running a simulation for 100 seconds with autosave set for every 10 seconds - and recording Solution History.
The first 50 seconds are ok, data is recorded in Solution History, - and let's say at 51st second a heat source switches on, solution runs till the end, again all the solution is recorded in Solution History for the whole 100 seconds .. and (because of typo in Field Function or too agressive solver setting or whatever) - it turns out that I have to rerun.
But to rerun - starting 50th second, not from the very beginning.
So I want to:
- rerun it starting 50 seconds, which can be done since I have an autosaved simulation and also first 50 seconds are recorded in Solution History;
- have solution history contatining data only for those first 50 seconds and for the following 50 seconds, but only for a successful run.
How can that be done?
Loading simulation autosaved at 50 s, correcting (whatever caused problem) and launching - results in Solution History containing data for the first 50 seconds (ok), for following "faulty" 50 seconds (not ok) and for following "good" 50 seconds (ok).
Any ideas?
cwl is offline   Reply With Quote
Mass flow rate history over solution step- rhoSimpleFoam gian93 OpenFOAM Post-Processing 0 December 8, 2019 11:20
Log printed history of solution Shubham_J SU2 2 July 25, 2019 10:29
Unsteady simulation solution files in parallel gunnersnroses SU2 1 December 15, 2015 14:28
Why 3D solid-pore geometry showing diverged solution? Sargam05 OpenFOAM 0 December 3, 2012 16:45
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 03:58
