How to convert a coordinate system into a position vector? |
July 31, 2020, 08:09 |
A. Mier
Rep Power: 6 |
I want to use this coordinate system's origin as the center of an object and then compute moments occurring on the faces of this object relative to the origin.
For this I thought of multiplying the force vectors by the position vector resulting from this coordinate system. Is it possible to do this in Star CCM+? |
July 31, 2020, 10:59 |
Ping
Rep Power: 20 |
it is much simpler than that since you have the moment report built in which has properties to allow you to set the csys and the part(s) to measure on
July 31, 2020, 11:25 |
Chaotic Water
Rep Power: 18 |
Also - in case of necessity you can set your own coordinate system.
July 31, 2020, 12:41 |
A. Mier
Rep Power: 6 |
I have tried the built-in reports but they give wrong results in comparison to the Literature. I am dealing with an open channel flow where I am trying to compute the moments due to the hydrodynamic forces of the water.
From my simulations I understand the built-in functions consider both hydrostatic and hydrodynamic forces, and I only require the hydrodynamic component. So I created a vector field function for the hydrodynamic force as explained on a different post in this forum. However, when it comes to the moment I am unable to get the right approach, so I thought that by multiplying this vector force by the position vector would give me the moments about the center of the object. |
August 1, 2020, 01:29 |
Ping
Rep Power: 20 |
well unless you are using the moment report incorrectly i suspect your model has a problem since i've never had a moment report lie.
but it is not hard to create your own moment report using the force vector field and the radial component of a local cylindrical csys you create at your required axis. |
coordinate system, moment, position vector |
[ANSYS Meshing] Coordinate system Import to Fluent | superduke1200 | ANSYS Meshing & Geometry | 4 | December 16, 2018 04:41 |
how to make orthogonal helical coordinate system in FLUENT for helical tube case? | teguhtf | FLUENT | 2 | October 10, 2018 22:01 |
Orient Mesh along local coordinate System | Dog92 | ANSYS | 1 | December 15, 2017 05:11 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
Coordinate System | selim | CFX | 1 | October 26, 2007 22:08 |
