July 29, 2020, 23:12 |
HELP! Plot values not matching TimeStep
Ali
I am studying turbulent flow around heated cylinders aligned one after another. I am able to simulate the flow and get reports. I made Nusselt number (Nu) reports for each cylinder and created monitors and plots from them. Once the simulation is done, I export the plots to MATLAB for the analysis I want to do. My issue is that the plots dont show the value of Nu at each timestep. My timestep is 0.005s but the values in the exported files go up in steps of 0.03 I don't know how to fix this since I need to use the proper timestep in my MATLAB analysis. Is it possible to fix this? Or is there some truncation that Star automatically does when plotting values from reports? Thanks! |
July 31, 2020, 02:25 |
Ping
Rep Power: 20 |
i imagine you are exporting monitored values from your reports and thus the problem is probably the trigger setting in the monitor not being set to your required setting of time-step
starccm+, timestep |
How to plot rms values? | Jem01 | OpenFOAM Post-Processing | 3 | April 12, 2017 09:52 |
Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 03:59 |
[snappyHexMesh] jagged, ragged edges... | ziemowitzima | OpenFOAM Meshing & Mesh Conversion | 138 | July 23, 2012 23:41 |
Need Help- Values not matching | umm.. | FLUENT | 0 | February 22, 2008 09:28 |
hw to plot the values at each grid point | rashmi | FLUENT | 0 | April 13, 2006 07:38 |
