Bulk temperature of periodic flow
Old   July 16, 2020, 12:55
Post Bulk temperature of periodic flow
Alex014 is on a distinguished road
Hello.
I 'm currently trying to calculate a circular tube model with a fully developed flow, but I'm faced by a probldm.
The procedure to specify the region condition is as follows:
1. Apply a constant temperature to the side wall.
2. Define velocity inlet on the inflow surface and pressure outlet on the outflow surface.
3. Create a periodic interface (type: fully developed interface) on these two faces.
4. Drive the flow with a pressure gradient.
I would like to perform a calculation where the hot mainstream is isothermally cooled by the walls, but I can't find a way to specify the bulk temperature for the inflow surface.
What should I do?
Computational model:
3D/Gas/K-Omega turbulence/implicit unsteady flow/constant density/segregated flow/segregated fluid temperature
Alex014 is offline   Reply With Quote
boudary condition, bulk temperature, fully developed interface
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
periodic straight tube flow, no mesh independent solution for pressure gradient thijs1909 FLUENT 5 May 16, 2018 10:04
Ansys CFX problem: unexpected very high temperatures in premix laminar combustion faizan_habib7 CFX 4 February 1, 2016 18:00
Periodic channel flow with time dependent mass flow rate QBeast FLUENT 3 May 10, 2013 14:14
calculation of bulk temperature in channel flow moshe FLUENT 0 May 13, 2007 10:57
